stuart colgan 0 Posted April 10, 2007 Report Share Posted April 10, 2007 Over the bank holiday I installed a new Alpine 9870r in my 94' VR6, and all went well, even managed to wire up my direct ipod cable and everything! However....everytime I now start my car my radio station presets are not there... they are not being stored. I know that this is prob due to my power source for the stereo being connected to the ignition, BUT I NEED HELP! What wire have I not connected properly, what should I do??!!! Regards Link to post Share on other sites
EmkayVR6 0 Posted April 10, 2007 Report Share Posted April 10, 2007 If u listen to a cd, does it go back to the start of the cd when u turn it off and back on or does it play from the last place it was in? It sounds like u haven't got a constant live feed to the unit so every time u turn it off it resets itself Link to post Share on other sites
vr6madmike 0 Posted April 10, 2007 Report Share Posted April 10, 2007 There should be 2 power wires and usually they have a push connection built into them so you can swap them over red and yellow i think? Link to post Share on other sites
EmkayVR6 0 Posted April 10, 2007 Report Share Posted April 10, 2007 yeah thats right my alpine loom is the same, The yellow one is usually the one that provides the constant live and the red one takes a feed from somethin like the ignition. I couldn't find a constant live inside the dash without takin it all out so just ran a wire direct from the battery inthru the dash and into the yellow wire Link to post Share on other sites
stuart colgan 0 Posted April 11, 2007 Author Report Share Posted April 11, 2007 thats right, i havent tried it with a CD yet but the IPOD plays from the start again, not from the place it last stopped! Once ive left the car and remote locked it , then gone back in the radio had reset itself! so it may be an ignition issue...a permanent power source prob! I have connected both the yellow and red wires so I am stuck when it comes to more wiring! any more ideas very welcome! (i) Link to post Share on other sites
Karr-Man 0 Posted April 11, 2007 Report Share Posted April 11, 2007 the way i would do it is take both the red and yellow wires and twist them together. make sure the ignition is switched off. connect the red+yellow connection to your in car wires in turn and see if the stereo turns on. if the stereo will turn on u have found your constant power wire, this should be wired to yellow, then connect red back to the ignition power soucre (or leave them both connected if u want the stereo to woirk with the ignition off.)if theres no wire that will run the stereo ignition off while connected to red+yellow then u need to lay iun another line to the battery ( remember a fuse)gl Link to post Share on other sites
marshall_01 0 Posted April 11, 2007 Report Share Posted April 11, 2007 This may heve been said but...plug the red to the yellow and yellow to redtrust me...used to fit these all day long. Link to post Share on other sites
stuart colgan 0 Posted April 12, 2007 Author Report Share Posted April 12, 2007 cheers marshall, will try this evening and let you know the outcome! Link to post Share on other sites
Seademon 0 Posted April 13, 2007 Report Share Posted April 13, 2007 If you get stuck u could call my mate Paul of Caesr Car Alarms, he'll be able to help u over the phone as he does this everyday 07770 794445 Link to post Share on other sites
stuart colgan 0 Posted April 16, 2007 Author Report Share Posted April 16, 2007 thanks for everyones help, much appreciated...and u were all right, the red and yellow cables needed to be connected to eachother... the headunit now remembers stuff! Link to post Share on other sites
