previous thread - replacin front disks
the black diamond combi disks and preditor pads are now on my vr, but im now getting a scraping sound, in the haynes manual it said that new pads should be 14mm thik including back plate, i have sanded the top layer of the pads of but they remain about 18-20mm thik, so i think there scrapin the pads as im driving, will this cause any problems or will they ware down to the corect width them selvs, sould i file them down to the correct width?
u sure the discs aint catchin the back plates ... they should ware down but mite take a while ur lookin about 20,000 miles if not more for a set of pads to wear out... can u trun the wheel freely when its jacked up if not the then barkes are stickin on and they will get very hot very fast a bugger the brakes and possibly get brake fade which is not good
iv jacked the car up and the wheels turn freely it was still makin a scrapin noise on the passanger side , there was like a thin disk behing the acutal break disk and a tinr bit was tuchin...iv bent the thin disk back so no more noise....the pads have abut a 1mm between them and the disk..happy happy joy joy
