removing heater matrix
  • 2 months later...
Dash out is easiest way.
Pete, in your engine bay on the bulkhead you'll see 3 10mm bolts, with big washers on done up onto about 20mm of thread sticking out. 2 in the middle one on top of the other and one near the top on the pass side. Undo all 3 and the whole heater box should come out if everything inside is undone.
Pull it directly backwards as you need the length of the thread to get through the holes.
Then the matrix just pulls out the top.
Tom.
