I know this subject has come up before but i can't find it looking back.
I am looking to get a new oil cooler and was wondering if anyone had any knowledge on them and also where to buy them from.
Looking for one that is thermostat controlled.
speak to Vince at stealth racing' date=' i was talking to him about them when i was there... they reduce the temp by upto 15 degrees![/quote']
Absolutely. The kit comes from Think Auto but the VR6 sandwich plate is custom made, which they always seem to forget in the kit if you order directly. Vince knows exactly what is required, so it's best to let him do the ordering and then post to you.
Yep it's DIY and if it fits in front of the radiator on a Corrado, it certainly will on the Golf. I found a 20 degree drop with a 13 row cooler. I was getting 116 cruising at 80 mph but now it rarely goes over 96, but then the VR lump is pretty cramped in the Corrado bonnet.
If you're getting high temperatures you might also want to ensure the thermostat is OK and there are no air locks in the coolant system.
