I've had her for nearly 2 years now, bought from my mate after he had just built it so i ended up with a very well sorted conversion.
Its a 2.8 out of a passat, corrado rad, 280mm brakes, hydraulic clutch, vibra front mount, fully polybushed, Eibach ARB's, VR6 spec suspension, full magnex with decat pipe.
As for the rest of the car it looks pretty standard, different lights front and back, still using my mk2 clocks so it looks original and a set of G60 edition blue electric recaros.
It made at Stealth 196.2 bhp @ 4993 rpm
210.2 lb ft @ 4026 rpm
This is my last mk2 VR, I killed it though... I miss this car badly!!
Stef
thanks.... yer i'm well pleased with the torque figure to. I don't no why it came up so high. You can really feel it aswell, it pulls a lot smoother than the OBD2 lump that was in my white one.
All i know is the original owner of the passat that the engine came from bought a brand new block and head and rebuilt the whole lump, so i can only assume he did a bit of head work. It made it into the mk2 with only 39k on the clock :0)
Stef
