mulberry man 0 Posted January 17, 2007 Report Share Posted January 17, 2007 my header tank emptys in about a couple of days but only when the engine is running i cant see any obvious leeks on the pipe work, any help would be greatly apreciated cheers! Link to post Share on other sites
VR6Pete 1,455 Posted January 17, 2007 Report Share Posted January 17, 2007 hi mate, check around your thermostat housing... coolant should be quite easy to spot as it will be dry pink stains around the area...Pete Link to post Share on other sites
matth76 1 Posted January 17, 2007 Report Share Posted January 17, 2007 If you can't see any obvious leaks after looking around the thermostat I would get a compression test done to show up any possible problems with your head gasket as that can sometimes be a cause of mysterious coolant loss. Link to post Share on other sites
petervr6 0 Posted January 17, 2007 Report Share Posted January 17, 2007 If you can't see any obvious leaks after looking around the thermostat I would get a compression test done to show up any possible problems with your head gasket as that can sometimes be a cause of mysterious coolant loss.just what i was about to say if you cant see any water around the ov places then i would say its the head gasket is there excess white smoke from the exhaust it would be very steamy like a kettle boiling water.lol if you know what i mean Link to post Share on other sites
