Vag-com MAF test question
Bear with me
For a general idea of what the maf should read, peruse these maths.
You have 2.8 litres. It takes 2 revs to fill all cylinders to suck in the whole 2.8 litres of air.
Got to take volumetric efficiency into it, to simplify it we'll only work with wide open throttle so we can forget the restriction of the throttle plate. Lets go for a VE of 85% at 6k. Its a reasonable estimate given you have filter/6 branch/cams to help it breathe.
2.8litres x 85% = our new capacity - 2.38l
so do 2.38 x revs / 2 (remember 2 revs to fill all 6 cyl) and you get your litres per minute.
divide by 60 and you get litres per second.
so 2.38 /2 /60 x rpm
in this case 6000rpm
119 Litres of air per second.
ok now at 0 degrees C air weighs 1.293 grames per litre
119lps x 1.293g
153.8g/s
Again that only works at wide open throttle cos it doesnt take into account the restriction of the throttle plate.
Also very rough maths, and only taken air at 0 degrees C and guessed volumetric efficiency. so there a fair margin for error.
saying that i work out 153, you get 150. I'd say thats close enough to say that 150g/s at 6k is about right 8-| :)
You could use the maths backwards to work out your volumetric efficiency. be interesting to see who flows best, or work out VE of std VR.
Better VE = more air in = more torque = more power. therotical max tourque of an NA engine is 100%VE (Although 100% is impossible to achieve).
*VE is rpm dependant so would need to be at a set rpm. Max VE of the engine will be where you see max torque.
Tom.
