m4t_lee 0 Posted December 15, 2006 Report Share Posted December 15, 2006 I tried taking the panel out the other day, there is a white plug which i disconnected but there seems to be lots of cables attatched which prevent me from taking the panel out. I only want to replace the illumination blulbs, any ideas?Cheers,Mat Link to post Share on other sites
Bigjobbo 0 Posted December 15, 2006 Report Share Posted December 15, 2006 The cables are for your vents, but i havn't removed one myself, but the cars i have done you can remove and refit the cables, although i do recall a sale on ebay, for a heater box, and it came with the panel still attached!If thats the case you'll have to whip the dash out.Hope that helps Link to post Share on other sites
m4t_lee 0 Posted December 15, 2006 Author Report Share Posted December 15, 2006 Oh arse, mine will be the dash out one i bet )I'll have a closer look in the amCheers,Mat Link to post Share on other sites
mike 6 Posted December 16, 2006 Report Share Posted December 16, 2006 i need to know this only the middle heater lights up on mine and the ash tray doesnt light either. im sure it not a dash out job! problem is i have air con and says in the manual to never remve the unit Link to post Share on other sites
m4t_lee 0 Posted December 16, 2006 Author Report Share Posted December 16, 2006 VR Moto, i have air con too, does it say not to remove the heater dials and if so why not?Cheers,Mat Link to post Share on other sites
blackmagic 0 Posted December 16, 2006 Report Share Posted December 16, 2006 Pop the front fascia panel off first to reveal four securing screws. Undo these then push the heater panel gently into the dashboard, you should now have just enough room to unclip the white shroud that sits round the bulb. The shroud and bulb can now be detached from the wiring plug. Refitting is the reverse.No need to remove the unit from the dash at all...Only one bulb is used to light the three dials its fitted as above, there is a film fitted behind the dials which the light uses to transmit its glow too the outer two dials. Hope this helps ya both out.Graham Link to post Share on other sites
blackmagic 0 Posted December 16, 2006 Report Share Posted December 16, 2006 Forgot to mention my vr has aircon so no problems with doing the above. You are not disconnecting the panel just moving it to get access. Link to post Share on other sites
petervr6 0 Posted December 16, 2006 Report Share Posted December 16, 2006 just done this 2nite as above facia pops off then x4 screws Link to post Share on other sites
