rosscovwvr6 0 Posted November 16, 2006 Report Share Posted November 16, 2006 hello i am new here ,and to the vr6, and it looks a good site.anyway to the problem ,i have a 1993 vr6 and it seems too slow. It accelerates ok and evenly but there seems to be no performance, no head snapping back type thing.I had the car on a scanner and it come back with 3 codes they are00525 oxygen sensor-g39 no signal occurs intermittantly00561 mixture adjustment adaptation limit (add) exceeded occurs intermittantly00513 engine speed sensor-g28 no signalso my question is would any of these make my car run poorly and what do they mean?thanks Link to post Share on other sites
Jk* 0 Posted November 16, 2006 Report Share Posted November 16, 2006 Well if theres faults then i would say yes. Faults often mean something somewhere is wrong! Link to post Share on other sites
Dave Lea 4 Posted November 16, 2006 Report Share Posted November 16, 2006 engine speed sensor is the prob if that is wrong will mess the fueling up Link to post Share on other sites
rosscovwvr6 0 Posted November 16, 2006 Author Report Share Posted November 16, 2006 thats what i thought but after searching on here it seems that the engine speed sensor fault shows because the engine wasnt running is this right? Link to post Share on other sites
Dave Lea 4 Posted November 16, 2006 Report Share Posted November 16, 2006 my frend had the same codes on my scanner changed the speed sensor and it was sweet...his was very slow befor the new sensor Link to post Share on other sites
Dave Lea 4 Posted November 16, 2006 Report Share Posted November 16, 2006 gfs 80 sqwid piss to fit Link to post Share on other sites
rosscovwvr6 0 Posted November 16, 2006 Author Report Share Posted November 16, 2006 i'll be doing that this weekend then ,cheers Link to post Share on other sites
Dave Lea 4 Posted November 16, 2006 Report Share Posted November 16, 2006 no probs mate Link to post Share on other sites
Steve @ 1 Posted November 17, 2006 Report Share Posted November 17, 2006 Speed sensor will show up if you scanned it with the engine turned off. First one looks like a lambda sensor fault, not to sure about the second one. Link to post Share on other sites
spanky 0 Posted November 17, 2006 Report Share Posted November 17, 2006 Speed sensor will show up if you scanned it with the engine turned off. First one looks like a lambda sensor fault' date=' not to sure about the second one.[/quote']I always check my codes with ignition on, but without the engine running, and I have never had the code come up for 'engine speed sensor'! Link to post Share on other sites
rosscovwvr6 0 Posted November 17, 2006 Author Report Share Posted November 17, 2006 ok checked it again on scanner and all of the codes had gone except for the speed sensor oneso i will try to get one but its too much for me to spend this week, bloody bills.anyone got a good one for cheap! Link to post Share on other sites
rosscovwvr6 0 Posted November 18, 2006 Author Report Share Posted November 18, 2006 had a play today took out speed sensor and gave it a clean it was no different then i unplugged it and the car would not start so to me this shows that it is working?also noticed car will hit a limiter at 5000rpm is this related?and where is the hall sensor? Link to post Share on other sites
Dave Lea 4 Posted November 28, 2006 Report Share Posted November 28, 2006 still looks to be crank sensor or poss cam sensor more crank with tha prob Link to post Share on other sites
Steve @ 1 Posted November 28, 2006 Report Share Posted November 28, 2006 Sounds like its definitely the cam position sensor to me. Had exactly the same problem with mine, a new sensor restored it to full health! not cheap though ~ £45. One owner saw a 25Bhp loss with a faulty cam sensor on a corrado VR. Faulty crank sensor will in most case's not allow the engine to start. Cant see how the problems you describe point to the crank sensor. Link to post Share on other sites
