c3vrg 2 Posted October 23, 2006 Report Share Posted October 23, 2006 my 1993 2.0 16v corrado is being a pain about going into gear .the gears are all over the place and sometimes first is where reverse is and 3rd gear is where 1st should be .any ideas i know its a cable change gearbox but could it be worn links etc ? Link to post Share on other sites
c3vrg 2 Posted October 23, 2006 Author Report Share Posted October 23, 2006 found it on vr6 forumit's very easy, 1 13mm nut. if you look down onto the top of the 'box, there's like a slide, nut on the end of the bolt facing towards the engine, keep it in nuetral, tighten that nut; that's central neutral, i.e. level with 3rd and 4th. It worked so i was well shocked took me 10 secs to fix the only spanner i had at home was the correct size a bit freaky.. Link to post Share on other sites
c4mbl 1 Posted October 24, 2006 Report Share Posted October 24, 2006 Link to post Share on other sites
