Leemo 0 Posted October 3, 2006 Report Share Posted October 3, 2006 I want to blank my ECU but as soon as i disconnect my battery my alarm go's off please help cause my car is running pish! Link to post Share on other sites
Petesvw 0 Posted October 3, 2006 Report Share Posted October 3, 2006 You not got a key to turn the alarm off? Link to post Share on other sites
Leemo 0 Posted October 3, 2006 Author Report Share Posted October 3, 2006 no wether car is opened or not when you disconnect battery it goes off Link to post Share on other sites
c4mbl 1 Posted October 3, 2006 Report Share Posted October 3, 2006 can u not just disconnect the alarm for the duration of the ecu resetting?? Link to post Share on other sites
mk3anni 0 Posted October 4, 2006 Report Share Posted October 4, 2006 can u not just disconnect the alarm for the duration of the ecu resetting??Cat 1 alarms cant' be disconnected at will, if they could they'd not be cat 1. Link to post Share on other sites
Leemo 0 Posted October 4, 2006 Author Report Share Posted October 4, 2006 And it is so does that mean it cant be done? Link to post Share on other sites
Petesvw 0 Posted October 4, 2006 Report Share Posted October 4, 2006 Do you not have a seperate key to turn the alarm unit off??? Link to post Share on other sites
Leemo 0 Posted October 4, 2006 Author Report Share Posted October 4, 2006 No, just a remote button and it doesn't disable the alarm when you disconnect the battery. Link to post Share on other sites
Petesvw 0 Posted October 4, 2006 Report Share Posted October 4, 2006 If you had a key to the alarm, this would answer your probs mate! You could de-activate the alarm, then re-set the ECU.Is there not a sequence via the fob you can go thru to do this?What alarm system is it? Link to post Share on other sites
Leemo 0 Posted October 5, 2006 Author Report Share Posted October 5, 2006 I dont no what make it is, there is no book of words for it Link to post Share on other sites
Petesvw 0 Posted October 6, 2006 Report Share Posted October 6, 2006 What about looking on-line? Link to post Share on other sites
matth76 1 Posted October 6, 2006 Report Share Posted October 6, 2006 I had exactly the same problem when I needed to disconnect my battery... the only way you can stop the alarm bleeding your ears is to use the small key you should have ...it simply goes into the alarm box on the driver side of the engine bay just underneath the windscreen washers. It is a small key about an inch in length... if you haven't got it then you could get one made up (I assume) with the key fob code (please tell me the seller gave you that when they sold you the car - otherwise you will pay through the nose if you lose or break your key fob) If the previous owner didnt give you any paperwork for the alarm then your local VW dealer should be able to help you and give you the contact details. Link to post Share on other sites
Leemo 0 Posted October 23, 2006 Author Report Share Posted October 23, 2006 Thanks mate! i do have that wee key so i will give that a go. It is a different alarm from standard but no paper work or book. I have been on holiday for two weeks thats why i haven't replyed. Link to post Share on other sites
Chrisdut 0 Posted October 23, 2006 Report Share Posted October 23, 2006 block the front of the siren nice and tight with rags, remove battery, it will still go off but if you block it enough it wont sound anyway near as bad Link to post Share on other sites
Leemo 0 Posted October 23, 2006 Author Report Share Posted October 23, 2006 Looked around and found the key for the alarm but I'm not sure where the key hole is. Any tips on the where abouts. My alarm is up next to the battery so any navigation to this hole will be very helpful. Link to post Share on other sites
