got the after run coolant pump of and found that it rattles.
after stripping it down i discovered 2 components had unsoldered themselves, due to heat
ok i thought i will try my spare on my other vr,
that was the same but with only one component unsoldered
has any one else had this problem?
any ideas where to get one or two cheap
thanks i tracked the multi problem down
the fan controller was shot,and a knackered temp sensor in the rad, the car gets to 95 on tick over then the fan cuts in , the after run coolant pump is now working fine as well.
the bently manual says that if i bridge pin 1 and 3 on the yellow temp sensor connector then the 3rd speed fan and the after run coolant pump should cut in, it doesnt? *-)
