h3lter 0 Posted August 23, 2006 Report Share Posted August 23, 2006 i used to have a clio and was a cliosport member, and they used to have pictured documentation on showing you how to do the basics, and was just wondering if there was anythin like that for the golfs? if not can some one just quickly tell me best place to get the power through the bulk head on a highline?thanks h3 Link to post Share on other sites
VR6chris 0 Posted August 23, 2006 Report Share Posted August 23, 2006 Their should be a rubber gromit that you can remove which take you throw the bulk head into the passanger foot well, Thats how a did it. Link to post Share on other sites
blackmagic 0 Posted August 25, 2006 Report Share Posted August 25, 2006 No problem if you look below your expansion bottle (right hand side near bulkhead.) You will see a rubber gromit about 2.5" in diameter if you remove this and make a hole in the middle of it you can poke your power cable through it. The end will then came through bulkhead in car under neath passenger side glove box. Just remember to seal round the hole in the grommet with sealer and refit the grommet into the bulkhead. Job done. Link to post Share on other sites
SiGainey 1 Posted September 1, 2007 Report Share Posted September 1, 2007 Anyone got any pics? There's a round rubber grommit behind the expansion tank that looks to pass into the pollen filter area and then there's a major one below with a few other wires in it.I took out the lower glove box but couldn't see where it would come through... TIA Link to post Share on other sites
SiGainey 1 Posted September 3, 2007 Report Share Posted September 3, 2007 Anyone know which grommit to use? Link to post Share on other sites
ventovr6essex1 0 Posted September 3, 2007 Report Share Posted September 3, 2007 i used the one that was slightly lower as its easer to find the wire behind the heater box . Link to post Share on other sites
ben_notts 0 Posted September 5, 2007 Report Share Posted September 5, 2007 you might find it easier if you take the glove box out - i did and then used a flexi fibreglass rod to feed it through the bay Link to post Share on other sites
SiGainey 1 Posted September 25, 2007 Report Share Posted September 25, 2007 I took the lower glove box and tried feeding the cable through from the engine bay but couldn't see it appear behind the glove box. Which grommit are people using - there seems to be 3 possibles![lightbox=../../e107_files/public/1190737390_2656_FT132656_dsc04273.jpg][/lightbox] Link to post Share on other sites
mannie 0 Posted September 25, 2007 Report Share Posted September 25, 2007 I used the big grommit behind the expansion tankI remove the lower clove box and peel back the sound insulation to make life easy .(hello C.) Link to post Share on other sites
ben_notts 0 Posted October 25, 2007 Report Share Posted October 25, 2007 same. thats where mine drops through, a fibreglas rod makes the job much easier Link to post Share on other sites
