craggsy 91 Posted August 19, 2006 Report Share Posted August 19, 2006 I had the web page for the fitting of a schrick on my computer but lost it all when I upgraded, so can anyone point me in the right direction. And can someone advise where the wires from control box go as the guides aint very precise, and don't wanna splice into wrong wire Link to post Share on other sites
richievr 1 Posted August 19, 2006 Report Share Posted August 19, 2006 me too i wanna knoe the same thing - my control box turned up today - want to get the vsr up and running!!where do the control box wires go to ????? Link to post Share on other sites
dubloke 4 Posted August 19, 2006 Report Share Posted August 19, 2006 if u dont find any docs on it, i'll take some pics of mine and where the wiring goes on manday as i'm at work till then Link to post Share on other sites
antera309 3 Posted August 20, 2006 Report Share Posted August 20, 2006 I've had a Schrick VSR fitting guide sitting around for months that I've been meaning to upload to the Knowledge Vault premium members section. It includes full instructions for wiring up the control box.I've just put it up.http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?132209.0enjoy! Link to post Share on other sites
richievr 1 Posted August 20, 2006 Report Share Posted August 20, 2006 thanks nick...perfect!! Link to post Share on other sites
craggsy 91 Posted August 20, 2006 Author Report Share Posted August 20, 2006 Nick you're an angel.....gives me plenty to do now with schrick and brakes to put on Link to post Share on other sites
mk3anni 0 Posted August 20, 2006 Report Share Posted August 20, 2006 Errrr guys be aware, the wiring colors are different between ODB1 and ODB2 Link to post Share on other sites
craggsy 91 Posted August 20, 2006 Author Report Share Posted August 20, 2006 Errrr guys be aware' date=' the wiring colors are different between ODB1 and ODB2[/quote']Tell me more? Link to post Share on other sites
mk3anni 0 Posted August 20, 2006 Report Share Posted August 20, 2006 Well there not the same!!!!the looms have different colors. I found this out when i fitted my schrick, I had the ODB1 diagram and when i hooked it up the car ran like a sack of shit. Ended up looking at another ODB2 that had a schrick to get the wiring colors. Link to post Share on other sites
antera309 3 Posted August 21, 2006 Report Share Posted August 21, 2006 If anyone knows what the OBD2 wire colours are, please let me know and I will make sure they are included in the guide. The three wires used by the control box are the +12v feed, the earth wire and the tacho signal wire. Link to post Share on other sites
VR6Pete 1,455 Posted August 21, 2006 Report Share Posted August 21, 2006 Nick, Didnt I email you the VGI fitting info a while ago? this was for the obd2 I beleive.Pete Link to post Share on other sites
richievr 1 Posted August 21, 2006 Report Share Posted August 21, 2006 If anyone knows what the OBD2 wire colours are' date=' please let me know and I will make sure they are included in the guide. The three wires used by the control box are the +12v feed, the earth wire and the tacho signal wire.[/quote']so does that mean your fitting guide is for an obd1 engine - which i guess makes sense as it came from the corrado club???i hope so then i can get fitting !! Link to post Share on other sites
richievr 1 Posted August 21, 2006 Report Share Posted August 21, 2006 Well there not the same!!!!the looms have different colors. I found this out when i fitted my schrick' date=' I had the ODB1 diagram and when i hooked it up the car ran like a sack of shit. Ended up looking at another ODB2 that had a schrick to get the wiring colors.[/quote']Do you still have the OBD1 wiring diagram ??? by any chance ????or do you remember which wires go where . . . ??? Link to post Share on other sites
antera309 3 Posted August 21, 2006 Report Share Posted August 21, 2006 Errrr guys be aware' date=' the wiring colors are different between ODB1 and ODB2[/quote']Good spot on the OBD2 wire colours, mk3anni. I have checked the Bentley wiring diagrams and you are absolutely correct.It is only the 1.5mm +12V feed wire (to ECU pin 23) that is a different colour on OBD1/2. It is red/blue on OBD1, black/yellow on OBD2.The earth wire (to ECU pin 1) is 2.5mm brown on all modelsThe tacho wire (to ECU pin 22) is 0.5mm green/black on all models.I have amended the Schrick fitting guide accordingly.If in any doubt at all, just go by the pin numbers above. These are the same on OBD1, OBD2, Syncros, Passats, Sharans, everything. Link to post Share on other sites
craggsy 91 Posted August 21, 2006 Author Report Share Posted August 21, 2006 Good call by Steve there, could of been a few people scratching heads!!!!Cheers for the guide Nick, and a very informative thread Link to post Share on other sites
richievr 1 Posted August 21, 2006 Report Share Posted August 21, 2006 THANKS PEEPS ..MUCHOS GRASIAS !!!!i know what i'm doing this week Link to post Share on other sites
dubloke 4 Posted August 22, 2006 Report Share Posted August 22, 2006 see, told everyone steve had his uses! Link to post Share on other sites
