Schrick fitting
I had the web page for the fitting of a schrick on my computer but lost it all when I upgraded, so can anyone point me in the right direction. And can someone advise where the wires from control box go as the guides aint very precise, and don't wanna splice into wrong wire
Well there not the same!!!!
the looms have different colors. I found this out when i fitted my schrick, I had the ODB1 diagram and when i hooked it up the car ran like a sack of shit. Ended up looking at another ODB2 that had a schrick to get the wiring colors.
If anyone knows what the OBD2 wire colours are' date=' please let me know and I will make sure they are included in the guide. The three wires used by the control box are the +12v feed, the earth wire and the tacho signal wire.
so does that mean your fitting guide is for an obd1 engine - which i guess makes sense as it came from the corrado club???
i hope so then i can get fitting !! :)
the looms have different colors. I found this out when i fitted my schrick' date=' I had the ODB1 diagram and when i hooked it up the car ran like a sack of shit. Ended up looking at another ODB2 that had a schrick to get the wiring colors.
Do you still have the OBD1 wiring diagram ??? by any chance ????
or do you remember which wires go where . . . ???
Errrr guys be aware' date=' the wiring colors are different between ODB1 and ODB2
Good spot on the OBD2 wire colours, mk3anni. I have checked the Bentley wiring diagrams and you are absolutely correct.
It is only the 1.5mm +12V feed wire (to ECU pin 23) that is a different colour on OBD1/2. It is red/blue on OBD1, black/yellow on OBD2.
The earth wire (to ECU pin 1) is 2.5mm brown on all models
The tacho wire (to ECU pin 22) is 0.5mm green/black on all models.
I have amended the Schrick fitting guide accordingly.
If in any doubt at all, just go by the pin numbers above. These are the same on OBD1, OBD2, Syncros, Passats, Sharans, everything.
