bigpol 0 Posted August 14, 2006 Report Share Posted August 14, 2006 im putting a vr into a 91' mk2 in the next week or 2, the mk2 has a mk3 gti 8v fuse board by the looks of it(due to a 2E 2.0l conversion in the past) is this the same as a 93 vr6 board? what about the harnesses for the lights and dash components do these just plug and play? i want to fit the mk3 goof clock pod but i dont know how neat and tidy the drivers eye view is going to be is there any way of fitting say a G60 clock pod and butchering the wiring to suit? maybe a corrado dash conversion to accomodate the rado clock pod which looks a damn sight better than both of the above ideas! any ideas or thoughts will be greatly appriciated. Link to post Share on other sites
bigpol 0 Posted August 15, 2006 Author Report Share Posted August 15, 2006 ok ive sorted the dash query out, just need to know about the clocks what have people used in theyre mk2s? cheers. Link to post Share on other sites
VR6Will 0 Posted August 15, 2006 Report Share Posted August 15, 2006 i used mk3 vr6 clocks in mine,you can use mk2 clocks and put 2 1k resistors in between the coilpack and the rev counter to get it to read correct. Link to post Share on other sites
bigpol 0 Posted August 17, 2006 Author Report Share Posted August 17, 2006 and thats it? quality! i know there are a few different types of clocks which one do i need its got the later type in it i think? Link to post Share on other sites
speedo 0 Posted August 30, 2006 Report Share Posted August 30, 2006 I also have used mk3 clocks in mine. plus i`m running comlete mk3 front lighting and power loom coupled to mk2 headlight connector. You have to shave a fraction of the top of the dashboard so as to raise the clock up into alignment, and move the side brakets slightly to fit the wider clocks. Link to post Share on other sites
