VR6Treg
Everything posted by VR6Treg
  1. Since you bring up the immo aspect I ordered a kessy. I will clone it and use it as a spare. I ordered a used on with the same part number. Do you recommend any tools for ecu and kessy cloning? I found a post where the guy used carprog to clone the kessy. http://www.codecard.eu/carprog/software/programmer/s4-7-kessy-tool-a8-toureg-phaeton-cayenne-pin-code-reader/prod_167.html For ecu flashing I will use galletto and nefmoto flasher. I also have a genuine ftdi obd cable. If I can do without boot mode it's be great but i was told I will have to open both original and sp
  2. I get it but not there yet :-) I was thinking of it like this: ecu is a computer which runs an operating system. When you flash it you're installing the operating system of your choice. I thought the flash/eeprom programming will make the ecu a full clone of the original if the hardware is the same. The closest I can get is an ecu with the same letters for a 3.2 VR6 Touareg but not the same engine. I'll start with this one and see how it goes. This is my first attempt at ecu cloning and this is only a personal project to have a spare ecu so sorry to bother you with basic s
  3. Thanks for the info. I understand that reading flash/eeprom from my 022 906 032 BE and writing it 022 906 032 BT will be hit and miss? I don't plan to do a plug and play swap. I want to create a clone spare ecu based on the content of my ecu, no tuning.
  4. Guys, a bit off-topic: Are me7.1.1 ecus with same part number except last two letters interchangeable or not? Example: 022 906 032 BE Can I replace with 022 906 032 BT ?
  5. This a 2004 3.2 v6 Touareg. PCV is new and was working before the valve cover replacement operatiin. The variable intake shifter rid does not move/change position.
  6. Hi guys ! First post here. I replaced the valve cover on my Touareg and messed up the variable intake system I guess. What's your take on this sound?
