Godlexxx
About Godlexxx
Namibia
Morning gents,hope all v-dubs are behaving well. i would like to ask a bit of info on the transmission brace that bolts on to the pinion shaft from inside the bellhousing without opening the trany. does this mod work,and what is the whole idea behind this mod,is there anyone that has done it and is it posdible to fabricate one?
Thanx bro,i think ill get a 2mm midell layer machined and just add the top and bottom halfs of mk4 gasket... just curious as to if arps are really needed.. i plan to run max 0.5 bar stock bottom end,standalone ecu,1 step colder plugs and front mount intetlcooler,want to step it up to about 0.8 bar once decompression plate is on. you think that will be safe?
Godlexxx reacted to a post in a topic: Advice on fueling needed for vr6 turbo built
kaashifmann reacted to a post in a topic: Advice on fueling needed for vr6 turbo built
I think i'll just wait for the standalone ecu,will have it in about 2 weeks time... i was wondering what you guys think of the ngk bkr6e plugs as in my country i cant seem to find bkr7e plugs,and also what thickness is the middel part of the head spacer that a lot of guys are using to get to 9.0:1 compression ratio? thanx a lot for the replies so far. want to upload some pics but have problems in doing so
Thanx a lot friend,will try to get a wideband kit.. im only looking for 260-300 whp,will that be ok for the stock tranny and clutch set up? nex year will be doing decomperssion spacer,440 injectors,arp top and rod bolts. do you perhaps know at what rpms i will start seeing boost with this setup? Godwin
Forgot to mention,my stock regulator is 3bar and i have a custom short intake mani as well..
Hi all im new to this club and need some solid advice urgently. I have a 95 mk3 vr6 golf,which im busy turboing.i am a diesel mechanic by profesion so i have good knowledge of cars. Theres my setup thus far.. T3/t04e 50 trim cold side, .82 a/r hotside Turbo smart 1:1 rising fuel regulator Twin 34mm forge reciculating valves 50mm hks style waste gate Custom 2.5" stailess steel downpipe 2.5" stainless steel freeflow exhaust system Oil catch can,manual boost controler Custom 3" cold induction with k&n filter,front mount intercooler with 2.5" s
