v6horse
About v6horse
The Netherlands
Why did you sell up all of a sudden ? Shame was a lovely car mate
Oil in water. Water in oil!! Help
v6horse replied to Moochalargo's topic in Engine Maintenance and Problems
Did you have the head checked for cracks ? -
Wish i could .. but only in the uk from the 29th to the 7th .. havent had my car up the stip yet .
Ill have a poke around my motor later again for you and see if i can find anything else .
My 1995 vr6 supercharged at the moment will do about 600 km on a tank motorway use when I drive between Holland and the uk via calais its lovely. I cannot complain with its motorway economy but town use it is horrible . I can maybe see 150 - 200 km on a full tank but then again there are allot of stop starts involved . When I first got the car it was running rubbish and would get if im lucky 400 km on a full tank . after a revised cylinder head , the supercharger new fuel pump and filter and a very nicely tuned ecu from the vr6specialist i gained around 200 km on a tank motorway use . Cant com
As far as im aware the largest wheel size you can go in the vr6 is with 17inch . i have some brock 17s with 225 45 17 tyres and even after the arches were rolled its still rubbing so having to go to 215 40 17 to stop this . So i would defo so 18 wont fit .
No Problem . I had the front of my car off this weekend as i needed to change the thermostat housing and for the life of me couldnt find any yellow plug on mine, and had no other black plugs apart from the 2 on the horn and 2 for the indicator and foglight . I did however not long ago remove the carbon canister and that did have a valve that did have a black plug if I remember correctly connected inbetween the canister to the inlet manifold . Other than that i cannot think what the black plug you have left is from . Good luck bud and loving a polo sedan vr6 :-)
The header tank plug is black with a brown/red and blue/red wire on my obd1 car
Did you not change the calipers for the 312 setup ?
I Had that lambda fault once . and i believe i had to change it and it was gone .. but not 100% sure it was that code . and what is the Max engine speed exceeded ? i havent seen that one befor on mine anyways and i have had most lol
the one i got that replaced my broken one has the Same partnumber on Top just with the Letter A after it but the lower part number is different and it only has 2 fuses where as mine had 3 . it works but the fan will only engage at full speed so do need to find a replacement . If anyone has a fan control unit with the following numbers . 357 919 506 Top Big numbers 89 8718 000 lower Smaller Numbers If anyone has one with this please let me know what you want for it . Cheers
Left over plugs on Polo VR6 conversion....
v6horse replied to Drizz's topic in I.C.E, Security an Electrical
Hello mate . the top one could either be the double horn or the foglight . thats the only connectors near there on mine with this type . the horn should have 2 of these connected as its a double horn system atleast on mine . cant tell you what the otherone is as i dont have any that color on my headlight loom . Hope this helps a little -
Hi Guys , My fan control has decided to start smoking on me and as soon as the battery is connected the fans turn on and nice smoke comes from the mod , i know a guy who has 1 but wanted to know if the part numbers must match exactualy . Need to know as soon as possible . Cheers
Cheers for the reply lukey will look them up .
ok cheers for the reply mate . I had totaly forgot to get them sorted while the car was in the shop . Will see what they cost from vw other wise will ask the bodyshop what they think .
