About breeza18
ripley derbyshire
just to add the turbine housing is 18cm so similar to 1.00A/R
ok so bit of an up date........bought myself a bigger turbo! its a holset H1C and its a lot bigger than the last effort. it has a t3 flange fitment so i bought a weld on t3 flange to make my manifold. below is a picture of my plan. can anyone see this being an issue with a standard obd1 inlet manifold? i know it needs one pipe making longer and a wastegate flange putting in but you get the idea. one more question.......after offering up my weld on T3 flange is it ok to port the area marked on this next picture?
change of plan, managed to get myself a holset H1C dirt cheap but needs a rebuild. gonna couple this to a homebrew ram horn manifold.
cheers Kev, deffo didnt pay that much for it! i know what your saying about the exhaust temps being completely different but folk have been using holsets and alike off cummins diesels for years with out problem? think il stick it on ebay and if it sells il use the money for a different turbo, if it doesnt then i might stick it on and see how it goes. has anyone run a holset/garrett turbo from a diesel on here?
hi jim, ive searched the perkins number and can find a little bit of info but no compressor map, the perkins number is 2674398. thanks for the heads up on the traders section, gonnna have a look now
i bought it off a local chap so no link to the turbo im affraid ive just measured the compressor out let and its 2 inch external and 1.5 internal. can i ask where you would get the info kev as i cant find it on the garret website, i have however found its from a perkins diesel engine at 3.9 litre, keep the info comming please kev as im hoping ive not dropped a b*****k with this one! a few pictures for you all........
hi kev, thanks for the input, ive just bit the bullit and got what i think is a dirt cheap brand new garrett gt32, problem is it looks a bit small on the compressor side, these are the markings...... compressor A/R .42 turbine A/R .82 the inlet to the turbo is about 53mm but reduces to 40mm turbine outlet is 70mm reducing to 50mm at the blades, does anyone think the compreesor is the wrong size??
yeah figured that much might just run an ebay item to get it up and running then up grade when it gives up. will i need 4inch maf for 300ish bhp?
cheers guys i read the diy turbo thread and thats how i got this far, bungy how much we looking at getting a manifold made? been looking for a cast spa one but cant find much without goin to usa.
what sort of spool do you think this will offer? im looking for 3/3500rpm? its ext wastegate so i know i need one and also know about the boost pipes and blow off valve. as for the engine, 120k but will be getting new chains and guides when i take the head off. wasnt gonna bother with the ARP stuff as im not chasing silly numbers, my golf weighs less than a ton so 300ish will be plenty lol
hi all im thinking of turboing my mk2 vr6. current spec is 6 branch and 268 cams with a stealth remap. ive been searching for turbo info as i was a complete noob to it all but have now come to this........ decomp plate, cylinder head rebuild garrett gt3283 hot side A/R .82 cast ebay manifold intercooler RRFPR bigger injectors 360cc/440cc and a remap after all running. im hoping this little lot will make me around the 300bhp mark and not spool to early as i dont want the grunt till a little later in the rev range but to the limiter, will this turbo be up to that? am i missing anything?? any fu
they open the valves further and for a longer duration. i run DRC 268s on a standard head with remap to a 6800rpm limit with no probs
hhhmmmm ok il check prices then. did you still have to use a press once you had warmed/froze the parts?
thanks for that, whats needed to get the old guides out? im guessing there press out/press in? id rather change them for piece of mind
anyone??
