veedubdave
About veedubdave
SE London
Cam identification - without removing cam cover??
veedubdave replied to veedubdave's topic in Engine Tuning
Thanks Kev -
Got a early ABV 2.9 Lots of uprated parts all over the car and i am aware the engine has had a full rebuild in the past. I am just trying to work out how far the rebuild went. ie. standard or cams, ported head etc. Through the oil filler i can see a casting ID of OT-1 on the rear cam does anyone know if this is standard or if there is something special lerking!? Thanks.
prob best to buy a rough corrado and sell the spare bits on, weight the shell in etc. will work out cheapest and you can test it all before fitting it.
I've heard you have to have the engine ecu reprogrammed to man if you do this swap? Reading above that may not be the case? Obd2 going into a mk2.
yeah the pipes go pretty hard, the system is spose to be under some presures as this raises the boiling point of the coolant. make sure you have the right mix of coolant and water also.
£179 for a full day - on track as much as you want - no timed sessions. £25 for and additional driver or £10 for a passenger. so not too bad if you trust someone to split the driving with! Think they are also doing half days the same day. but there not half the price so i think the full day is better value if you can streetch to it. link here: http://www.motorsportvision.co.uk/trackdays/event-details.asp?ProductID=4710 I did one in my corrado in jan at bedford with the same company and it was a great day. Anyone know of any cheaper days/ websites? can get sessioned days cheaper but you onl
I am planing to do Brands on 18th March if anyone is interested via MSV.
rear suspension
veedubdave replied to peeriehutchie's topic in Wheels, Brakes, Suspension and Steering
the threded part should come up a couple of cms, if your talking more than a couple or 3 cms you prob have the plates and bushes in the wrong order.
