joelounge
About joelounge
london
brake caliper upgrade
joelounge replied to joelounge's topic in Wheels, Brakes, Suspension and Steering
just spoke to Hi Spec, for the vr6 they only do a kit....which works out over £800 (EEEK!) going to hold out for some S2's me thinks!!!! -
Hi I want to upgrade the calipers on the vr6..... are there any that fit on the standard size discs??? Comp brakes don't make a kit and it seems that willwod don't either?!! Thanks
hi my driver's rear window has stopped working! i can hear it make a small click when the switch is pressed but no action. any pointers as to what to do how to go about it please! thanks Joe
Hi just up grading my brakes to grooved and drilled and want to change the pads as well.... any recommendations? use the car only at weekends and live in london so hardly banging around a race track!! want something that won't ruin my wheels and lasts a while????? Any advice welcome ta
so 60mm should be totally cool? Does any one know about tyre width on a 16' rim?? Also stretching tyres???? how small do you go???? Sorry for the questions new to this!
Hi I am about to fit some coilovers and springs on my 5 door... How low can i go with out any issues? also I am up grading to 16" rims and how wide should I go with the tyres? Any advice appreciated! ta
just gathering all the parts for a stage 1 cnversion, who is best for a remap? and do i need to chamge the standard injectors? if so to what? Thanks
http://cgi.ebay.co.uk/VR6-Genuine-Superchip-Golf-Corrado-Jetta-2-8-2-9_W0QQitemZ260329255863QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item260329255863&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A10|39%3A1|240%3A1318
ok so if you remove the fuse the abs stops working and so does the traction control? What happens when you plug it back in? any problems with it resetting? Is the braking effected?
how do you turn it off?
so does your traction control interfer or aid you?
used to race in uk street racers which is a street legal series. Just wondered if the basic mods made much impact or boost/charged is the only way to get lower numbers? Used to run a 70's opel kadett with an isuzzu turbo lump with gas that went very well. just fancied the odd rwyb and the old traffic light battle!
Hi I am just getting in to vr ownership and wondered what to expect from the vr golf on a Drag Strip? What is standard trim time? And then what can you get with what mods? Which tyres? Can the traction control be a hinderence? Who on the site is the qickest???? Thanks
ok so its a aaa! Thanks
Hi how do i find out what my engine code is?? Thanks
