r36 syncro
About r36 syncro
berkshire
3.6 mk2 syncro and 3.6 mk2 supercharged
r36 syncro replied to r36 syncro's topic in Members Rides and Event Photos
Got it put on the rollers but i need bigger injectors as it starts running lean after 5400rpm ... so i will get new injectors and a bigger fuel pump and have another go .... -
New Stronger manifold ... -
i hoping i can get the manifold to hold and then i can turn the boost back down - and know its not going to blow again. -
This is the first time the welds have broken since we fitted this manifold - i think i need those stainless steel pipes that you have got ... i didn't really want to have the piping made untill i could get the manifold to hold properly just incase i had to move the throttle for the new config ... But you are right the material needs to be thicker and i need stainless pipes....i measured the boost pressure before it popped 32psi @ 7500 rpm. -
what boost you running pops? -
The manifold is made from 6- 8mm ally plate , Thats what 2 bar of boost does unfortunately. you have to remember that this is only a prototype design we have a new version to put on this monday so stay tuned. what do you run pops ? do your pipes flex... -
Hi Phat, You are completely right we are looking at ways to improve the prototype all the time as you can imagine it was a lot of fabrication work just to get it this far but give us a couple of weeks and we should have it sorted. -
short video -
http://www.r32oc.com/members-rides/6534-my-ongoing-project-golf-mk2-syncro-3-6-a.html my ongoing project.
