jamieherd
About jamieherd
Fife
Missing and loud popping noise
jamieherd replied to jamieherd's topic in Engine Maintenance and Problems
Sprayed the coilpack with a water last night, the pack started arcing in 3 or 4 different places. Mainly from where the HT leads plug in, down onto the plastic cover. Any suggestions on the best/cheapest place to pick one up?? -
Cheers peeps! will give that a try later on. -
Driving home from work today and drove through a large puddle. Straight afterwards the car was only firing on 5 cylinders or less and there was a few loud popping noises coming from the engine bay. It did clear eventually tho. It is not the first time the car has done this but is defo the worst. After having a search on the site I think it could be the coil pack. Any suggestions??
Calico, Did you ever fix this problem?
I have had the code read for the ABS fault, number is 00283. Which i believe is a faulty sensor. Just strange that after the garage tightened up the wheel bearing it was fine for a few days.
All new on mine too! U think it could possibly be steering rack?
Did changing the bearings make any difference?
This problem i'm having seems to be getting worse, has anyone ever had a knackered wheel bearing before without it making a rumbling/grinding noise?
Is it possible this could be a worn rack as i'm feeling every bump etc thru the steering wheel
May seem like a silly question but what year of TT do the solid bushes come from? Looking into getting some.
Been having some issues with my handling for a while now. The car is wandering all over the place, the slightest gust of wind or bump/crack in the road and its heading for the nearest hedge. Its at the stage now where I feel unsafe. A few weeks ago I had finally had enough and took it to my local garage to get them to check over the handling problem and to fix a problem with the ABS. I got a call from the garage about an hour later saying that the wheel bearing was needing tightened up and this is also what was causing the ABS problem. I was under the impression that the front wheel bearings a
So by unhooking the top and bottom rad hoses will this drain all of the coolant from the system including the block? Or am i gonna have to take stat off to do this?
Guys Looking to do a full coolant change at the weekend as my coolant is a getting bit dirty. Was gonna start by letting the engine warm up to normal operating temperature so the stat opens then undo bottom rad hose. Will this release all of the coolant in the block and radiator? Does anyone know of a better or correct way of doing this? I was also going to use holts speedflush? Is this any good.
Cheers guys. Planning to get some leather soon as the cloth interior is starting to look a bit shabby, then i'll probably start looking at power upgrades. I'll also look out the autoglym bumper care
