mashed
About mashed
Sunny Worthing!!!!
Hi Guys, I have a head I am just about to rebuild for a VR6, Has anybody done a guide? I've had a quick look and can't find anything..... Thanks Brad
Hi Dude, It's wired into the loom near the auxiliary water pump and distributor, all three wires theres a two pin plug and a three pin plug next to it....... I'll get a picture up in a minute......
Hi Guys, I'm carrying out a vr6 conversion, I have a plug which I Can't explain, It's a 5 pin plug with one brown two blacks and a purple black and blue and black........... any ideas what it is........ Thanks Brad
That's the dude he's on CGTI http://www.clubgti.co.uk/forum/showthread.php?t=192243
I'll swap you! I have a golf one in a cupboard and need the corrado one! PM Me thanks Brad
Hello, I'm 90% Done, Easiest way for an F as is mine, Is to get all the 90 Spec Electrics from a MK2 (Either G or H Reg) (I went to an Auto Electrician and it cost £1800 for a car that still barely works) Fuel Pump, Loom, and so on, Then you need a Hydraulic Clutch Pedal box from a Corrado Mk3 Subframe (Mk2 Wishbones are fine if you want to keep standard track) Bigger front brakes (16v Hubs 280 Carriers and Calipers G60 Discs and Pads) You will need to dent the Chassis leg Like the VR Corrado The engine is a bit wider! And Bigger Master Cylinder to move the larger amounts of fluid, And a
Hi Guys, I have just completed a VR6 Swap, and their seems to be a problem, As when it starts it's fine, But it won't stop! You have to unhook the battery and then try starting again to stop it, Does anybody have any ideas? And also i have a couple of spare wires? A green with Black tracer and a yellow..... Thanks in advance, Brad
Hello, I pm'd you over on mk2vr6 i need the wiring sorting out on my conversion? Can you let me know? Cheers Brad
oh my god, that's awful, it looks like a matchbox car i thought it was one when i first saw it!
