Hi guys - i'm new here, but at least i've found some cool folks with similar attraction to these damn VR6s.. Welcome from the UK! OK, the car runs rough and misses bad under load and really struggles to build up revs. So far the following has been checked/replaced:- On-board diagnostics checked and good New VW HT leads New coil New plugs Compression ratios good Temp Sensor Air Flow Meter Distributor, cap & rotor Crank Sensor Knock sensor is checked/good cam timing good no airleaks which i can feel/hear Any ideas????
