Antihero1981
Days Won
1
Antihero1981 last won the day on November 20 2014
Antihero1981 had the most liked content!
About Antihero1981
Essex
HI Does anyone have an electrical wiring diagram for the obd2 , i have a friend having a look at the Vento but he wants a diagram to see where the wiring goes and links up Thanks Ryan
HI , on the coilpack you have the plug , does anyone know which one is the 12v? i am not getting any power at the coilpack so i am not getting any spark , there is fuel Where does that wire come from? is it at the Ecu or the fuse panel? Thanks ryan
vento vr6 still not starting
Antihero1981 replied to Antihero1981's topic in Engine Maintenance and Problems
Yeah new coil pack , checked all fuses and nothing dude -
I have checked fuel pump and it primes up , you can hear relay clicking in on/off and you can smell the petrol , just does not seem to be getting spark. someone mentioned starter solenoid , -
Hi guys still having issues with the vento , vr6 obd2 1997 so I have changed the following new spark plus new coil pack new ignition switch new crank sensor new temp sensor and the vento still just cranks and not fires , I took off the coil pack wiring plug and don't get any voltage with the ignition on , this does not sound right. where does the coil pack get power from ? been 3 months and she is not running what else can I check?
Vw Vento The saga continues
changed sensor and still same problem -
Bealieboy reacted to a post in a topic: Vw Vento The saga continues
WelchFarf reacted to a post in a topic: vcds codes check
well , the last few weeks the vento went from driving spot on to not driving she would not crank , so I changed the ignition switch and that seemed to sort it for week or 2 , now I cant get her to fire up she cranks but does not do anything today I checked the following 1.fuel relay - getting power 2.fuel pump getting power circuit seems to be fine and when you crank it you can hear the fuel pump kick in so now I am thinking it could either be 1. spark plugs 2.ignition leads 3.crank senor 4.coil pack 5,injectors hooked up a code reader and didn't get any codes , only b021d which
Hi , so I attempted the vcds on the vento obd2 vr6 and it came up with the following , not fussed about the abs stuff but worried why I cant connect to the engine and the auto trans code anyone got any ideas? could not scan the engine , tried a few times kept coming up excessive comms errors VCDS-Lite Version: Release 1.0 Tuesday, 02 December 2014, 17:06:22:0 Chassis Type: 1H - VW Golf/Vento III Scan: 01,02,03,08,12,15,25,41,56 ------------------------------------------------------------------------------- Address 01: Engine Labels: 01M-927-733.LBL Controller: 021 906 256
Hi , whats a good scanner tool I can use to read fault codes/clear codes? they have the superscan vs450 on sale. looking for something cost effective as I don't use it that much thanks ryan
Obd 2 vr6 won't start after changing plug leads
Antihero1981 replied to Josh/vr6's topic in Engine Maintenance and Problems
lol sounds like the same issue I am having , -
D11PS reacted to a post in a topic: Vr6 odb2 engine cranking but battling to start
well relay is clicking away , did a few checks today and now she is even worse lol.looks like she is getting fuel as it sprayed out the FPR when I put it in wrong.lol.... but now she does not want to idle.....I tried the throttle body reset which didn't do anything. think I am being daft cause I lifted up the rear seats and there was no fuel pump hatch....and I cant find any hatch in the boot either.... so I am thinking , coolant sensor? crank position sensor? or vac leak , I didn't hear any hissing noises
Bealieboy reacted to a post in a topic: Vr6 odb2 engine cranking but battling to start
