HIGHLINE VR6
About HIGHLINE VR6
    LANCASHIRE
  1. Has anyone done this conversion? What would I need to do to get these brakes on my car? They fit in my 17" rims and believe in need to make some spacers to go between the Hub and the Carrier. Also, What brake lines would I require? and would I be able to use the R32 Disc Gaurds on the VR6 Hubs Help is needed and gratefully appreciated! The disc size is 334mm Dia. Thickness is 32mm. Thanks, Ian
  2. PUT ME DOWN, WAS GOING TO GO TO BRITISH VW FESTIVAL BUT CANT BE ASSED, LOL. AIR COOLED S****
  3. how do i do the adjustment myself? and how will its right, or do i just have to test it? some people have said put a full synth oil in it. do you think this will work? cheers for the advice, keep it coming
  4. right, so ive got to check the adjustment on me linkage first. i know how to chage the resting point of the gear stick but how do i adjust my linkage? what tools are required? what do i undo? and which way do i do it? cheers
  5. i own a 98 vr6 golf with 120k on it with cams and remap. when giving it some beans and change from 1st to 2nd it now and again crunches and somtimes 2nd to 3rd. but this only happens occasionally. i have recently put a sach repset clutch in and also a short shifter. is there any way of sorting this out? dont want it to happen half way up the strip! could be down to a slow clutch? or to quick a gear change? and how could i resolve this? any help is gratfully appreiated, ian
  6. HI EVERYONE. JUST A LONG SHOT. DOES ANYONE HAVE ONE OF THESE AMD THROTTLE BODIES FOR SALE OR KNOW OF ANY ONE WILLING TO SELL THERES? CHEERS, IAN
  7. where on earth would i get one of these from? what vehicles were they on exactly and what year? and does anyone know who has got one or where i could get one? greatly appreciated for the help guys, ian
  8. I OWN A 98' GOLF VR6 OBD 2. IF I WAS GOING TO PUT A SCHRICK MANIFOLD ON IT WHICH WAS A OBD 1 FITMENT WOULD I THEN BE ABLE TO RUN A 2.9 THROTTLE BODY? IS THIS POSSIBLE AND IS IT A LOT OF WORK TO DO ( DIFFERENT PIPE WORK, PLUGS OR SENSORS ) ? ANY HELP IS GRATEFULLY APPRECIATED THANKS, IAN
  9. I OWN A 98' GOLF VR6 OBD 2. IF I WAS GOING TO PUT A SCHRICK MANIFOLD ON IT WHICH WAS A OBD 1 FITMENT WOULD I THEN BE ABLE TO RUN A 2.9 THROTTLE BODY? IS THIS POSSIBLE AND IS IT A LOT OF WORK TO DO ( DIFFERENT PIPE WORK, PLUGS OR SENSORS ) ? ANY HELP IS GRATEFULLY APPRECIATED THANKS, IAN
  10. I OWN A 98' GOLF VR6 OBD 2. IF I WAS GOING TO PUT A SCHRICK MANIFOLD ON IT WHICH WAS A OBD 1 FITMENT WOULD I THEN BE ABLE TO RUN A 2.9 THROTTLE BODY? IS THIS POSSIBLE AND IS IT A LOT OF WORK TO DO ( DIFFERENT PIPE WORK, PLUGS OR SENSORS ) ? ANY HELP IS GRATEFULLY APPRECIATED THANKS, IAN
  11. COUNT ME IN, YEAH!!! COMING UP WITH THE NWVAG LOT, IN CONVOY FROM PRESTON AREA!
  12. ive got new pads and new discs. the rear wheel bearings are growling and so i have decided to change them. where should i get new bearings from, gsf or vw? and what other parts will i need to do job, someone mentioned to me about a abs ring? and what is the procedure for all this? very much appreciated, ian
  13. YOU CAN PUT ANOTHER VR ON THE OUTSIDE AND, IM DEFFINATELY UP FOR IT! WILL HAVE TO PUT MY SUMMER WHEELS BACK ON A COUPLE OF MONTHS EARLIER THOUGH, DOH!
  14. THERE IS A PUB JUST OUTSIDE TATTON PARK. ITS ON THE MAIN ROAD AND ITS CALLED THE SWAN. SHALL WE ALL MEET UP THERE AND GO IN TOGETHER. WHAT DO YOU ALL THINK & WHAT TIME SHALL WE MEET?
