gkjnr
About gkjnr
central scotland
i,ve got a supercharged vr6 in my mk2 golf and up til now i,ve been running a early mk2 16v pump but its on its way out as it keeps making strange noises, anyway i wanted to just replace it and looked at the haynes manual and it says that an early (87) pump is the one to go for as its 5 bar ,does anybody know where is the best place to get one or if there is an alternative, its the pump thats under the car and not the one in the tank by the way thanks
it was a faulty sender but i,m still going to need to cover the cooler as the oil temp is staying around 75 deg
i,ve had the temp sender in and out a few times so i may have knacked it ,when i get a new one we,ll see if the stat is working or not
any advice then? i,ve ordered a new temp sender from vw just in case mine has went faulty it,ll be in on wednesday so i,ll see what happens then
yes i,ll be tracking it , i,ve also supercharged it, i spent the extra so i would not have to cover it up in winter , its a pain in the ass as it was extra £40 i think its a mocal too so you,d think it would be good stuff
its a 13v row cooler theres no heat exchanger , apparantly the stat is set at 80 deg , is there any way i can check its working ok ,and not just a faulty sender for the mfa?
stealth mate ask for vince ,done me a chip and it sorted my problems with one phone call,plus he takes time to find out what you,ve done and what your looking for from your motor ,well recommended
help! foolishly jetwashed my motor now its missfiring
gkjnr replied to gkjnr's topic in Engine Maintenance and Problems
sorted now ,it was a wet maf -
it will sort itself out after driving for a while i,m led to believe mate
i,ve got the right parts for it now , i,d done about 20 miles and the temp still won,t come up. the reason i bought one with a stat was to cure the problem with it over cooling the oil
i,ve just fitted a mocal oil cooler and stat the thing is my oil tempreture gauge is not coming up past 60 even when giving it a thrashing, i understood that the oilcooler won,t start cooling the oil til it hits around 90 and that was the reason i bought one with a stat ,any ideas guys? the stat is the mocal type as well, could i have plumbed it wrong? it looks ok to me and the stat seems to be only able to be fitted one way ie the side with the gasket to the block and the cap on the side without the gasket
tps wires sequence anybody? checked the bentleys manual but no clues there -
just cleaned it yesterday, i,ll leave it a few days and see what happens -
could a lambda sensor cause this as well,i,m getting desperate , i don,t want to start flinging cash at it buying sensors and i don,t have access to vagcom -
na stupidly thought it would be ok ,any clues on the sequence of the wires to the tps, i rekon i might have got water in it cos when i unplug it the fault goes away(nearly) i,ve also had the cover off the roker cover and cleaned and sprayed the coil connections with wd40 but to be honest they were dry
