flexin
Everything posted by flexin
  1. OK I'VE HAD IT BACK ON VAG COM AND IT'S REPORTING NO FAULTS. THE ENGINE REVS FINE AFTER PUTTING ON THE NEW CAM SENSOR BUT IT'S STILL VERY LUMPY ON THROTTLE AND VERY POPPY ON DECELERATION IF ANYONE COULD HELP I'D BE GRATEFULL THANKS JOHN
  2. ok i have chaged it out for a new one and it has made a diffrence but hasn't completely cured the problem. one question i have is do i have to reset the ecu before it restores timing if so i'll try that. it now sounds like one of the cylinders isn't firing. so my question is that if the car has sat for a while could the coilpack have gone. it can't be the leads as they are new sames as the plugs. any help at this stage would be good thanks john i fogot to say that i can smell petrol in the exhaust
  3. i have the oportunity to have my vr resprayed and am wondering wether to standard idian red or go something diffrent so i'll put it to you guys give me some ideas (pics would be good) thanks john
  4. i picked my car up from the body shop today and the engine was running very lumpy and popping a lot out of the exhaust when i got it home i put it on vagcom and it come up with camshaft sensor error does this sound right or is something els likley to be the cause thanks john
  5. i had the same thing mine turned out to be the seal between the housing and the block. pesonally i think if you're taking it off to change the crack pipe seal do them all, saves doing it twice john
  6. hi guys i've pulled out the ashtray and there is no slide door anywhere behind it could it possibly be anywhere else?
  7. hi guys i need a little help finding my obd port i've tryed using the search fuction and cannot find any topic relating i have a 95 obd 1 with coilpack and have tryed behind the ashtray and behind the spare button slotsin the dash, In the footwells and am running out of cubbyholes to look also if i can find it i need to find a obd cable that doesn't cost $240 any help is appriciated thanks john
  8. just after a bit of advice on the way home today there was a bit of a bang steam up the windscreen and now coolant on the carpet, so i think the heater matrix has blown. Does this sound like the problem or could it be something else, also if i put all the controls on to cold will the car hold coolant so i can drive to get to work and get the parts at the weekend. oh and finally is it gonna be a pig to change thanks guys john
  9. yeah it's coming from behind that part but i can't determine exactly where but its definatly that part is this an easy part to replace as it looks quite buried thanks john
  10. hi guys just after a bit of help i've just noticed i have a water leak coming from just above the gearbox and next to the coilpack and at the front of the engine just wondering is this the water pump if so does it mean i have to replace or could a gasket have gone thanks john
  11. hi guys i'm just about to change to a set of coilovers and was looking to go for the fk highsports as i can't afford the damping adjustable's just wondering where i can some from and how much, and also how long for delivery as i'm normally quite an impatiant guy and money seems to burn a hole in my pocket. thanks john
  12. hi guys i'm just about to change to a set of coilovers and was looking to go for the fk highsports as i can't afford the damping adjustable's just wondering where i can some from and how much, and also how long for delivery as i'm normally quite an impatiant guy and money seems to burn a hole in my pocket. thanks john
  13. i had one of these on my rover 1.8 before i bought my vr and the diffrence was huge the rover had a flat spot around 2500 rpm after fitting it, it was gone and the car reved a lot more freely. i only had an induction kit and straight through exhaust on it so personally i like them john
  14. hey guys just been to look at the car today which still isn't fixed, i'm begining to think i'll never get it back! oh the new alarm they have fitted is a cobra don't qiute know what model yet but i had a toad on there before are these similar quality or should i push for something else? thanks john
  15. hi guys i have had a few developments in this saga. the bodyshop has fixed all the bodywork but have managed to break the alarm. So they now have to fit a new full closure alarm at their own cost. I don't know if i should be happy at the prospect of a new alarm or concerned that they broke the old one. john
  16. sorry i have just realised that the page is loading but i have to scroll down past the side banner before it starts doh how stupid do i feel now sorry john
  17. just thought i'd give everyone an update the bodyshop called and the car will be ready to pick up on monday all fixed. Is there anything i should look for in particular as to the work done or is it just paint finish panel gaps etc
  18. hey there i'm having a problem with some pages not loading i get the top and side banners but dont get any content for instance i can't view this page http://www.vr6oc.com/e107_plugins/forum/forum_viewtopic.php?95527
  19. i was just wondering if anyone knows of a decent wheel refirb company in the middx area just bought a set of oz wheels for my vr when it's all fixed from the bodyshop. Oh how much per corner should it cost? thanks john
  20. does anyone know how much air a golf vr6 sucks in per min @ full revs cheers john
  21. so far she has been quite good she has admited total fault to her insurance and they are arranging to take it into their garage to see if it's "economical" to fix. oh and the've given me a crapy 1.4 astra to drive in they wanted to give me a 1.0 ka but i told them to f*#k off.
  22. she was pulling off a petrol fourcourt through a line of traffic and accelerated into me. the photo doesn't show off how bad it actually is the list of damage is as follows front wing dented and arch moulding cracked door is mullered rear quarter panels has a small dent and is scuffed under the vr6 sign the rear bumper is scratched and scuffed and she cracked the wing mirror
  23. I cant belive it i've only had my vr6 a month and already some woman has mangled the door I'm gutted
  24. I have just finished changeing the brake fluid on my golf which was in a pretty black condition. which has led me to think that the clutch fluid must be in the same condition but i cant find where the resiovir is is for the fluid, is it the same one as the brake fluid. thanks
