zuludong
About zuludong
Greenock
Thanks for the replies guys, managed to fing a guy with that special tool gonna try and get it done soon before my arches eat my tyres.
Had this problem on my 3 door and it turned out to be water leaking through my rear light cluster seal. Check the carpet in the boot for dampness.
Hi guys, been looking to rebuild my vr top and bottom ends with uprated parts and eventually turbo it but whats the best supplier for the parts ie pistons, bearings, oil pump and stuff. Also wondering if i should go for a big valve head and increase my capacity to 2.9 or 3.0ltr while i'm going this far. Has anyone got any experience with this? Is it worthwhile.
Hello guys! Has anyone had their wheel arches flared rather than rolled before if so how is it done. Can you buy extensions that can be welded on or is it just a case of forming the arch already on the car? Any help would be appriciated, cheers. *-)
berfore you go to the hassle of taking the door panel of try greasing up the seals at the sides of the windows with some sort of sylicone spray.
yeh that was my other choice. is that your car in the picture what offset are you running.
Seen them on Dubmeister but not sure if the've got them in stock, might check that out later.
Hi guys! I've been trying to pick a set of wheels for my black VR6 Highline and am relly struggling. I fancy the deep dish look so I'm leaning towards a set of Kerscher Carmonas but do you think these would look good? Any thoughts would be much apprieciated and may stop me from going bald.
The correct way to measure ride hight is to measure from the centre of the hub to the wheel arch.
