volkswag0nvr6
Everything posted by volkswag0nvr6
  1. hi ppl, just had my mk2 vr6 re-mot today as it failed on emissions. i tryed fitting a catt to bring the emissions down but didn't change anything. its reading around 6 when it needs to be under 3.5 to pass. what can i do to get it down?
  2. thinking of buying some V-Maxx coilovers. V-Maxx is owned & made by B.V Hiltrac. B.V Hiltrac have only just started marketing these kits under their own brand (V-Maxx) although you will have seen their kits being branded under several names including Eibach, Weitec & FK Automotive The coilover suspension kit is fully adjustable, will go down to around 120mm Comes with full TUV approval, and a 2 year warranty. Includes the c adjusting spanner, and everything needed to get the kit on the car. priced at £305 what do you think?
  3. no nothing on here to help. thanks anyway mate
  4. hi people, im trying to get my mk2 vr6 going i have got no spark and it is not fueling. now i have tracrd out lots of wires from the coilpack to the ecu and they all seem to be fine. (done a continuety test on them) also when the car turns over im getting a signal at the coilpack.. i have checked out the fuel relay and there seems to be no supply to it. tracing the wires out red & yellow go to the fuse block, but dont get any voltage from it? green & blue im unsure of(think it goes to the air mass meter) red & white i cant trace and white goes to the ecu. can anyone shead any ligh
  5. ok im back again, a few of you might remember a few months ago i was on here trying to get a few pointers to get my mk2 vr running again. (no spark or petrol getting to the engine) after weeks of trying to get her going i failed and gave up so i took her to a auto electrical garage spoke to the bloke told him about the car and he was happy to take it on. they have had it for 3 weeks now. he phoned me today telling me after hours of scratching their heads they were unable to find the problem. he is not going to charge me for the time they have spent on her which is sweet... (sound bloke) so whe
  6. cheers for your help guys. will try putting a post on the corrado site
  7. yes the dash lights come on. im running the 2.9 corrado engine. i got the coil pack and crank sensor off a mk3 golf 2.8 lhd acident damaged. would that make any difference? i will check the vaccum pipe to the ecu. the earth is ok cheers lee
  8. hello again people, after 3 weeks now i haven't been able to get my mk2 vr6 running again. i have got no spark and no fuel. i have got power to the fuel pump and the coilpack. i have changed the following parts: coilpack, hall sender, crank sender and ecu. and still nothing. im lost now and haven't got a clue what to do next, so i guess it is time to get someone who knows what they are doing. Does anyone know of someone in the cambridge area who would be able to help? cash in hand thanks
  9. yes mate near newmarket. tryed another crank sensor today and still nothing. i know i said i had fuel but i don't, before i didn't take the fuel lines completey off and fuel p***** out, just took them fully off today and i am not getting any fuel. got power at the fuel pump but it is not running. so if i had no spark and no fuel it would suggest that the ecu could be knackered...
  10. just checked the crank sensor and it looks quite new, gave it a wipe down, all the surfaces were clean and free of rust. it is at red lodge. when i went last sat everything was ther apart fom the wheels and airbox. what are you after?
  11. nice, should save me a few quid. that is where i got the coilpack from. is there any other parts that would be worth robbing?
  12. nice one. cheers for that mate,will take it off and give it a good clean. looks like i will have to take the front end off to get to it tho. i know where there is a mk3 vr6 golf at a scrap yard near me (left hand drive) the crank sensor will be the same as the one on the corrado isnt it?
  13. think i am going blind lol can't see it anywhere thanks for your help
  14. ok think i have found it does it have 3 plugs going to it?
  15. having trouble finding the crank sensor, would it be near the coil pack somewhere?
  16. just had a closer listen, when i turn the ingnition on there is a clicking noise. but i don't think it is coming from a relay. but since then i have checked for power at the eco plug that goes to the coilpack and i have power there. aslo checked for power at the cam sender and that is fine. so i think it is safe to say that it is not the ecu.. i hope. i have been the crank sensor but if that was gone would it cause me not to have a spark? thanks
  17. yes when i turn the ignition on there is a click from the ecu relay.. does that mean the ecu is ok? if i was to take just the ecu down to vw would they be able to check it?
  18. found my problem.. 3 wires in the main engine loom have been cut some how and possibly shorted out. i have crimped them together, but she still wont start do you think this could have dammaged my ecu? cheers
  19. about a week ago she cut out. and wouldn't start again (no spark). since then i have changed the coilpack and the hall sender. and still nothing.. is there anything else i can check before i take it to a garage? thanks
  20. is there a way of testing the coil pack off the car? would like to know for sure before i buy one. found one for
  21. ok i will give that a try tomorrow when i get home from work.. i did try two of the leads for a spark and there was nothing there. are hall senders expensive, if not would it be worth me changing it so i know it is not that.. thanks
  22. how can you check the coilpack? and where is the hall sender located? cheers
