mrmoo
Everything posted by mrmoo
  1. Yes I cleared the fault code a dozen times, same fault either sensor. Back to my original thought, does anyone know how to recode this unit with out the original factory pin number?
  2. Thanks for the reply. It can't be the sensor, I swapped the channels, reversed the cables and got the exact same fault code. I've also checked the continuity of the wiring in the loom to the ECU plug and its continuous. Has to be something in the ECU, trouble is I can't recode as its looking for a login code.
  3. I?ve got a bit of a problem with my ABS. It?s a VR6 / 96 with the pump and ECU (TEVES 20) together under the bonnet. The ABS light came on, so I got VAG-COM and checked the fault. It said rear right sensor not working. So I checked it, OK resistance. Cleaned it anyway. Swapped the connectors with the left one and the same code came up. I?ve unplugged and replugged the ECU, can?t think of anything else to do. Am I right, is it either a bad connecting/broken wire or is the ECU knackered? Can anyone tell me how to recode an ABS controller? I?ve got one from Ebay and I have the software but I?m u
