malsvr6
About malsvr6
What's better than the VR6,and costs less than 10 grand?
malsvr6 replied to apd's topic in Engine Maintenance and Problems
under engineered,japanese turbocharged dogshit!!! sorry guys i worked for subaru once always blowin up -
L/H wheel front at angle??
malsvr6 replied to malsvr6's topic in Wheels, Brakes, Suspension and Steering
bushes are new poly's, i've just replace hub bolts from strut seem abit better old ones wer'nt vw -
Hi people, Had to take my RS4 alloys off due to ill fitment, was when i fitted original BBS back on the top of lert front is pointing inwards. I have adjusted the suspension at bottom of strut roughly by eye but soon as i moved the car it went back the way it was has any one had this before. vw are charging £120 for camber setting can't afford that just now
How does removing airbag stand for m.o.t?
took my rs4's back today, will try rs6 reps instead
Bought a set bout a month ago they are 7.5x17. They look the dogs twitcher but after i replaced the pads the caliper was hard against the wheel. no amount of spacer is any use. So if any of you fancy a set then make sure you have a pre 96 model they are the same as gti 16v. so i no have 18 inch fox rs. ~
you little beauty!!!!!!!!!!!!!!!
are they pricey?
yip!
thanx for your help mate, iv'e ordered parts today just to confirm about chain you were right mine is a 96 mdy with single chain set up. Also if anybody is goin to do this job make sure to check crankshaft oil seal mines leakin thanx again mate.
Ive fitted a piper x, sounded great but i felt it was better with a k&n panel filter
the guy im getting it from has two more systems in stock, the de-cat was ordered for sum1 but never collected eurotek fancied £290+vat for system ive only been charged £8 for postage.
just pulled my gear box out to rectify an annoying grinding noise comin from timing gear, i got new chain guide tensioners. has any 1 done this b4, vw dealer told me the chains never get replaced ?! . surely this cant be true. :@ :! :?
not sure what the de-cat is guys,but i called around a few places they said at least £310 inc vat for cat back and a 2week wait? (maybe thats cos i live near john o' groats) but this 1 was promised for 2morrow :|
thought the price was ok, considering a cat bypass was included and delivered next day.
