Everything posted by Paul Allen
Blast from the past!!? Does anybody have any info on this company they where based in Wembley i believe. I have some rather tasty dials in my VR that have Mykoo Motorsports on them and was hoping someone could throw some light onto what else the company done fot the VR. I seem to remeber a cover car by them back in a very old issue of Max Power Any Info would be appreciated Thank you please !!?
Coilpack / Fuel pump fuse / Relay !!!???
Paul Allen replied to Paul Allen's topic in Engine Maintenance and Problems
Thanks for the reply Kilokilla. Does anyone have any idea where to get a new coilpack from. They are 190 from VW !dodge and there are none on EBAY at the moment. -
I have a few problems with my Golf Vr6 94 ODB1, hoping you guy can help. Firstly story I was driving down the Motorway doing 70ish when the acc pedal went rock hard , felt if it was stuck. Pulled over on the hard shoulder and the car died, tried to start it would have any of it just turned over never fired. Popped the bonnet had a check of the usual MAF , plug leads etc all look fine. got back in the car started straight away i was'nt to sure what to think. Next day on the way down to my local garage conked out again same problem pedal hard etc.Called the AA out checked everything found it to
TT Comps - Polishing.
Paul Allen replied to Paul Allen's topic in Wheels, Brakes, Suspension and Steering
Thanks for the replys , going to pick them up tonite. I booked the garden shed out for the next month !!!? if anyone need's me i'll be in there. Binliner did you use the -
I have just had the result of my life , i have just won a set of TT comps from an online auction site!!? for the tidy sum of 160 pounds !amazed I would like to go down the tried and tested route of polishing them up (Binliner you input would be appreciated). They have'nt been curbed but the laquer is beginning to come away, so dont really need a refurb. I thought i give it a go myself, can anyone tell me the best way to go about it.
Thanks for your replys. I will be preping the car myself so can i clear something up will i have to drill the rivets out behind the plastic arches or will i just have to tidy up the paint behind the arches. I have'nt looked behind the arches yet so hopefully i will not get any nasty surprises.
VR monster I have'nt looked under the plastic arch yet to see whats growing under there!!?.I have to find some CL side trims to replace my ones. Let me know how you get on. Thanks for the reply.
Hi I have looked at at a few threads on here from people wanting to do this. My VR is going into the bodyshop the week after next to have some rust sorted out, i was thinking of taking the arches off and getting them to smooth whats left under the plastic arch. Is this an easy job? and is it really worth the hassle. Is there anyone that has done this that could give me some idea on how to go about this?
Just fitted a Momo steering wheel but lose the momo horn , so i ordered a horn from R& A. Just tried to fit it but cant work out which wire go's to which connector. There is only one wire coming from the boss and two connectors on the back of the horn. In the boss pack it came with an extra wire with a spade connector on one end. The boss has a collar that the horn go's into on this there is a spade connector but as soon as you connect the wire to this it makes the horn stay on. Can any one help me please? Does anyone have any idea what i am talking about!!!? !dodge
Flushing radiator / coolant
Many thanks -
Hi People What is the best way of emptying the radiator , as i have had a coolant leak because of a spilt hose. I will need to empty the old coolant and replace it , but what coolant shall i use. I had used G12 before and just want to check that this is suitable for the VR.
Thanks to everyone who offered there top radiator hoses, but i don't need as i have managed to get a brand new ones for FREE !lol from a friend who is replacing his with a Samco set. He is replacing all of the hoses that the preivous owners had just bought brand new from VW costing over three hundred quid!!!!? RESULT.
Thank you for the replys Dubloke, i have just been on the samco website and it says that they do not sell to the public you can only buy them through distributers. Do you know any where that sells these dirt cheap?
Hi people Coming back from work tonite pulled up onto the drive , i noticed steam from the bonnet. Opened the bonnet and there is no water in the tank x) . I have let it cool down and have found the problem the large hose (i think its called the cross over pipe could be wrong) has a pin sized hole in the end under the coilpack. I have attached a picture, does any body know where i can get this hose from as i imagine VW to be really expensive or should i bite the bullet and get some Samco's?.
drivers side window not working
Paul Allen replied to scruffy's topic in Engine Maintenance and Problems
I had a similar problem. In the end turned out to be one of the wire lifters which powers the window up and down this had got twisted. Your best thing to do is have a look on EBay or a scrap yard and buy your self a second hand one, i bought mine for fifty quid better than VW who only sell the window in different parts for silly money. It is to hard to tell which part is causing the window to be stuck best thing is to renew the whole thing. -
I posted a question a couple of days ago about my jumping rev counter. Did'nt get any reply so i searched the boards, the problem seems to be a dirty ISV!!?. I went to take it off this morning to give it a clean and found that the sound deadner has a hole in it. In the attached picture it looks like the sound deadner plugs into the long hose beside it. this is where i have the hole as the plug has broken leaving the pin sided hole. Will this cause the jumping rev's because of the air leak? and where if needed can i get a new ISV or sound deadner. Thanks in advance
Sorry for the long thread, here go's I have recently put a new Ram air Pro filter onto my VR and have now noticed some problems. Since fitting the filter i can hear a whistle noise coming from the engine bay, i have rechecked all jubilee clips and none are loose. The noise seems to come from a black plastic box shaped thing!!? that has two pipes going into it to the right of the throttle body. There seems to be a pin hole near the top right of this box. Is this what is making my rev counter jump and what is this box thing.Also the car seems to be holding back at around 3.500 rpm. The filter
I had pretty much the same problem as you , in the end i bought a second hand ABS pump and ECU from EBay for £50 and i am going to get Stealth to fit it. I let you know how i get on, as i am sure this is a cheaper option.
Nothing else came in the box just this big old air filter. I already have a K+N filter on the car but i don't think i can use the bracket for the K+N for the Ram Air there nothing to attach the bracket to the air filter.
Hi Everyone I have a couple of questions for all of you that have bought this quality street tin sized air filter !amazed I have bought the above filter brand new from a friend but it came with no instructions. I know how to fit it on (not exactly rocket science there!!), but for all the people that have one of these do you use cable ties to keep the filter from moving under load and where do you tie it too.
I have always used NS Racing since i bought my VR back in Feb 04. I have had a lot of stuff done there (poly bushes all round ,exhaust etc). Raj and the guys down there really know there stuff i have had no problems.
Hello Mate Try NS Racing just off the Edgware Road they have done work on my car and know there stuff.
Hi people Merry Crimbo Quick Question for you Only one of my Radiator fans works, my car is an OBD 1 (L reg) i believe that the other fan is run from the other one from a elastic band ( looking at picture attached ) where can i get this part (anyone with a part no please ). Can you put the band on without taking the front end off , or can you leave everything in place? Any ideas? [ 333_61_1.jpg ]
On my wheels i am running 215/40 as R - Tec said that they could'nt strech 205 over the wheel!!?. I am using the crap Halfords spacers which is now worrying . I have had the arches rolled but the wheel only caught on the inside of the coilover. I have booked the car into Stealth next weekso i will get them to check. Thanks for your help Minty
