About Paul Allen
St Albans , Herts
Blast from the past!!? Does anybody have any info on this company they where based in Wembley i believe. I have some rather tasty dials in my VR that have Mykoo Motorsports on them and was hoping someone could throw some light onto what else the company done fot the VR. I seem to remeber a cover car by them back in a very old issue of Max Power Any Info would be appreciated Thank you please !!?
Coilpack / Fuel pump fuse / Relay !!!???
Paul Allen replied to Paul Allen's topic in Engine Maintenance and Problems
Thanks for the reply Kilokilla. Does anyone have any idea where to get a new coilpack from. They are 190 from VW !dodge and there are none on EBAY at the moment. -
I have a few problems with my Golf Vr6 94 ODB1, hoping you guy can help. Firstly story I was driving down the Motorway doing 70ish when the acc pedal went rock hard , felt if it was stuck. Pulled over on the hard shoulder and the car died, tried to start it would have any of it just turned over never fired. Popped the bonnet had a check of the usual MAF , plug leads etc all look fine. got back in the car started straight away i was'nt to sure what to think. Next day on the way down to my local garage conked out again same problem pedal hard etc.Called the AA out checked everything found it to
TT Comps - Polishing.
Paul Allen replied to Paul Allen's topic in Wheels, Brakes, Suspension and Steering
Thanks for the replys , going to pick them up tonite. I booked the garden shed out for the next month !!!? if anyone need's me i'll be in there. Binliner did you use the -
I have just had the result of my life , i have just won a set of TT comps from an online auction site!!? for the tidy sum of 160 pounds !amazed I would like to go down the tried and tested route of polishing them up (Binliner you input would be appreciated). They have'nt been curbed but the laquer is beginning to come away, so dont really need a refurb. I thought i give it a go myself, can anyone tell me the best way to go about it.
Thanks for your replys. I will be preping the car myself so can i clear something up will i have to drill the rivets out behind the plastic arches or will i just have to tidy up the paint behind the arches. I have'nt looked behind the arches yet so hopefully i will not get any nasty surprises.
VR monster I have'nt looked under the plastic arch yet to see whats growing under there!!?.I have to find some CL side trims to replace my ones. Let me know how you get on. Thanks for the reply.
Hi I have looked at at a few threads on here from people wanting to do this. My VR is going into the bodyshop the week after next to have some rust sorted out, i was thinking of taking the arches off and getting them to smooth whats left under the plastic arch. Is this an easy job? and is it really worth the hassle. Is there anyone that has done this that could give me some idea on how to go about this?
Just fitted a Momo steering wheel but lose the momo horn , so i ordered a horn from R& A. Just tried to fit it but cant work out which wire go's to which connector. There is only one wire coming from the boss and two connectors on the back of the horn. In the boss pack it came with an extra wire with a spade connector on one end. The boss has a collar that the horn go's into on this there is a spade connector but as soon as you connect the wire to this it makes the horn stay on. Can any one help me please? Does anyone have any idea what i am talking about!!!? !dodge
Flushing radiator / coolant
Many thanks -
Hi People What is the best way of emptying the radiator , as i have had a coolant leak because of a spilt hose. I will need to empty the old coolant and replace it , but what coolant shall i use. I had used G12 before and just want to check that this is suitable for the VR.
Thanks to everyone who offered there top radiator hoses, but i don't need as i have managed to get a brand new ones for FREE !lol from a friend who is replacing his with a Samco set. He is replacing all of the hoses that the preivous owners had just bought brand new from VW costing over three hundred quid!!!!? RESULT.
Thank you for the replys Dubloke, i have just been on the samco website and it says that they do not sell to the public you can only buy them through distributers. Do you know any where that sells these dirt cheap?
Hi people Coming back from work tonite pulled up onto the drive , i noticed steam from the bonnet. Opened the bonnet and there is no water in the tank x) . I have let it cool down and have found the problem the large hose (i think its called the cross over pipe could be wrong) has a pin sized hole in the end under the coilpack. I have attached a picture, does any body know where i can get this hose from as i imagine VW to be really expensive or should i bite the bullet and get some Samco's?.
