ABS ECU Help - any one got one for sale???
Hi all,
Ive got a 1997 VR6 HL. The ABS light has been on and off for a while. Through elimination I have worked out that the fault is the ECU side of the connector. Ive replaced sensors, checked continuity etc - so im sure there is something amiss within the ECU.
My question is can you remove the ABS ECU from the pump/regulator without draining down the brakes and removing all the pipe unions.
There doesnt appear to be enough room on mine to drop the ABS ECU down and out - without it fouling the pipes.
And secondly - if I can't fix the ECU (I do electronics/soldering etc) then does anyone on here have a spare that I could buy - or know of somewhere where I can get one for a good price.
I dont have the part number - but I assume its standard on late VR MK3?
Thanks for any help!
Martin
