ian 182 0 Posted June 1, 2006 Report Share Posted June 1, 2006 When i turn my fan on in the car to no1 nothing happens and only when i move to setting 2 does the air come out of it...Also after about 20 mins of driving the switch becomes hot to touchAny ideas people???thanksian Link to post Share on other sites
ian 182 0 Posted June 19, 2006 Author Report Share Posted June 19, 2006 helpian Link to post Share on other sites
dellert 0 Posted June 21, 2006 Report Share Posted June 21, 2006 where is the resistor on MK3? My MK2 had a similar fault in as much as the fan only worked on fan speed 3, found the resistor was nackered, but the resistor was mounted on the fan motor. Not a lot changes at VW so I imagine the resistor is in the same place so although this would explain your fan speed problem it would not explain the heat. Link to post Share on other sites
VR6Rich 3 Posted June 23, 2006 Report Share Posted June 23, 2006 Both the resistors and switches on MK2's are known problems, so it may be possible that you need to replace both on your MK3. Link to post Share on other sites
Silver VR6 0 Posted June 29, 2006 Report Share Posted June 29, 2006 My heater control only works on level 4 so got myself a new heater resistor (4.99 buy it now on ebay!)...im fitting it tonight so i'll takes some pics of the process and post them up tomorrow... if im sucsessful!!! :-* Link to post Share on other sites
