MOT failure!! advice please
failed on 3 things
nearside front suspesnion arm has excessive play in a pin/bush
2. nearside shock absorber has serious fluid leak
3 nearside inner brake pipe excessively corroded
I wanted to change the suspension anyway, can anyone suggest a good midrange suspension that will give a decent stance and not brake the bank??
what sort of budget you after? try fk, they do spring/shox kits as well as coilovers for reasonable money! sounds like just normal wear and tear on the car tho tbh, they are heavy on suspension components vr's if you dont replace or upgrade the standard set-up!
G-Max also do a reasonably priced spring/shock kit for about £200. I'm more than happy with it on mine. Do a search for suspension on here. There's loads of good threads on the subject. You'll find all the advice you need there.
Kevin
Use grease on brake pipes after youv'e cleaned them up. Underseal will just make the inspector think you have something to hide.Also VR6Steve, those non-damping adjustables sound very exclusive, and very uncomfortable. Do you mean non-adjustable dampers? *-)
One thing to add about the GMAX kit is that all the dampers are gas dampers and not oil filled...so they are more reliable. If you live in the south give the Phirm a call as they will supply and fit them at a very good rate. They did mine...very happy with mine and certainly looks lower than the 35mm drop advertised...i would say it has dropped my car about 45mm.. I also fitted a deep front spoiler on mine and now it looks nice and aggressive but subtly so... not overly low but certainly looks good. No trouble over speed bumps. Perfect going round corners compared to stock suspension. Good luck mate.
