Campbell0240 0 Posted April 19, 2006 Report Share Posted April 19, 2006 I've been starting my car an letting it idle on the drive its building up to low 80-s oil pressure and hitting 100-110 on the temp gauge and theres no fan kicking in? Only if i turn the ignition off then fan starts up so is that normal or should there be a fan starting before it hits 100+? Whilst the engines running?Just wanted some advice any quick tests to chekc the speeds and to basically know what should be happening so i can go from there? Link to post Share on other sites
vr200 0 Posted April 19, 2006 Report Share Posted April 19, 2006 i thought that the fans wud only kick in when the water temp gets too high?? Link to post Share on other sites
Campbell0240 0 Posted April 19, 2006 Author Report Share Posted April 19, 2006 Sorry if i wasnt clear enough its my water temperature hitting 100-110 and i know the VRs are meant to run hot just wondering when they kick in? Link to post Share on other sites
vr200 0 Posted April 19, 2006 Report Share Posted April 19, 2006 well i have the rong thermostat in (90 degree) wen i shud have a 70 degree stat, so my fans kick in at around 100-110, so i wud assume so shud urs??? Link to post Share on other sites
jasvr6 0 Posted April 19, 2006 Report Share Posted April 19, 2006 had same problem with my vr mate and it turned out to be the thermostat had stuck closed. so fitted new thermostat and rad switch and water temp is at 90 and the fans now kick in. Link to post Share on other sites
