Help! The illumination around the headlight buttons doesnt light up any more the only bit that still glows green is the centre of the headlight knob everything else around it is black! Ive noticed that it could be a lose connection cos its done it a few times recently and ive just tapped the pannel and its all come back on again but last night no amount of tapping would work! Everything else in the car all lights up and works perfectly, any ideas? How do you get the pannel off?
You need to carefully prise the whole switch out in one go , if you carefully lever the abs panel out first you can then get to the side of the switch and guage where to start applying presure , dont pull by the round dial you turn the lights on / off with it should only come out just past the dash before you have too struggle with releasing the wiring harness. Hope that makes sense.
