p1vsg 0 Posted January 21, 2006 Report Share Posted January 21, 2006 i just got a diagnostic check on my abs system as the abs light kept lighting up. two fault codes came up:00285 - abs sensor (i think)and 01276 - hydraulic brake pump.i been told that by changing the sensor it might resolve the hydraulic brake problem. do you think this could be true? im having doubts im afraid.if the brake pump needs changing will the ecu need changing at the same time??thanx Link to post Share on other sites
poloman 0 Posted January 21, 2006 Report Share Posted January 21, 2006 Check the kontakt off ecu mabye is water in it.¤¤VR6-ZR¤¤ Link to post Share on other sites
