VR6Will 0 Posted January 10, 2006 Report Share Posted January 10, 2006 I have a 5bar twin pole vdo oil pressure sensor, it replaces one the oe sensors on the top of the oil filter housing but which one? the sensor for the blue wire or the sensor for the yellow wire? Link to post Share on other sites
kilokilla 0 Posted January 10, 2006 Report Share Posted January 10, 2006 are you trying to put a seperate vdo oil gauge in car if so you need a t-piece so you can connect new sensor and still keep old sensor aswell then you remove either of tth two sensors screw in t-piece screw old sensor you removed into t-piece then screw new 5bar sensor into other side of t-piece reason being that otherwise your oil light will keep coming on. Link to post Share on other sites
VR6Will 0 Posted January 10, 2006 Author Report Share Posted January 10, 2006 well the vdo sensor i have is a twin pole sensor, 1 goes to the gauge the other goes to the engine loom...ie replaces one of the sensors, just not sure which one Link to post Share on other sites
kilokilla 0 Posted January 11, 2006 Report Share Posted January 11, 2006 oh i aint come across 1 of them yet i will try and find out tomorrow for ya if know one responds b4 me. Link to post Share on other sites
kilokilla 0 Posted January 11, 2006 Report Share Posted January 11, 2006 right i cant say for sure but i have a 2.0 16v engine that has 1 fitted and that has replaced the darker of the 2 sensors so i would go with the blue 1 however if its wrong it wont hurt your engine it will just bring oil light on at which point you will know its the other sensor it will not affect the actual oil pressure so you wont harm engine. Link to post Share on other sites
VR6Will 0 Posted January 12, 2006 Author Report Share Posted January 12, 2006 yup, just gotta try it i suppose, Link to post Share on other sites
