I'm getting fuel leaking from the top of the fuel tank or something above it. Fuel dribbles down the left-hand side of the tank and onto the floor. This only happens when I fill the tank right up. If I only half-fill the tank, the problem never occurs.
It could be the seal around the fuel pump (the pump was recently replaced, and I'm sure a new seal wasn't used), but is there anything else it could be?
if you lift the boot carpet, there is a black circle with 2/3 screws in it, remove this and you will see the top of the fuel pump with pipes feeding into it, the jubilee type clip on these can loose tension and cause a leak here, i replaced mine with screw type jubilee clip.
try it = wont hurt
