antera309 3 Posted November 30, 2005 Report Share Posted November 30, 2005 I'm getting fuel leaking from the top of the fuel tank or something above it. Fuel dribbles down the left-hand side of the tank and onto the floor. This only happens when I fill the tank right up. If I only half-fill the tank, the problem never occurs.It could be the seal around the fuel pump (the pump was recently replaced, and I'm sure a new seal wasn't used), but is there anything else it could be? Link to post Share on other sites
bazz780 0 Posted December 1, 2005 Report Share Posted December 1, 2005 if you lift the boot carpet, there is a black circle with 2/3 screws in it, remove this and you will see the top of the fuel pump with pipes feeding into it, the jubilee type clip on these can loose tension and cause a leak here, i replaced mine with screw type jubilee clip.try it = wont hurt Link to post Share on other sites
antera309 3 Posted December 1, 2005 Author Report Share Posted December 1, 2005 Thanks, I'll take another look, but I'm pretty sure I couldn't see a julbilee clip round the fuel pump itself. Is it under that black ring?: Link to post Share on other sites
jezmoz 0 Posted December 1, 2005 Report Share Posted December 1, 2005 think he's on about the jubilee clips on the actual pipes in your pic ??? Link to post Share on other sites
antera309 3 Posted December 2, 2005 Author Report Share Posted December 2, 2005 I just checked and there doesn't seem to be any leakage from the feed & return pipes. Link to post Share on other sites
