VR6Pete 1,455 Posted November 9, 2005 Report Share Posted November 9, 2005 My brakes have suddenly gone pants (doesnt feel like there is any force apart from my foot! and my clutch is slipping....Now I know my slave cylinder needs replacing, I'm just a little concerned that it could be something else relating to my hydrolic system....Is there anything I can do diagnose the problem?Thanks,Pete Link to post Share on other sites
silverline 0 Posted November 9, 2005 Report Share Posted November 9, 2005 the clutch servo works off the master cylinder. if your slave cyclinder is leaking then you will lose pressure and the clutch wont operate properly. Link to post Share on other sites
Dave Lea 4 Posted November 10, 2005 Report Share Posted November 10, 2005 your cluth uses the same fluid from the brakes if that is low you will loose the brakes .... could have fluid on the cluth plate making it slip Link to post Share on other sites
