jayvwvr6 0 Posted November 8, 2005 Report Share Posted November 8, 2005 i know the later vr6 has larger size discs 280mm i think? but what about brake pads are they the same for all years and do the have low warning sensors fitted mines a 1997,thanks jason Link to post Share on other sites
FishWick 21 Posted November 8, 2005 Report Share Posted November 8, 2005 Late VR6s use 288 x 25mm discs. Earlier ones used 280 x 22mm discs. The 288 (ATE) setup uses much bigger pads than the 280 (Lucas/Girling) setup. Your 97 will have the ATE 288 brakes.You can easily distinguish 288s from 280s because the 288 calipers have a wire clamp on the front of them, which you can see through the wheel spokes.I think some cars had wear sensors. You'll soon know when you take the old ones off as there'll be a wire attached to one of the pads on each side.Stick some Ferodo DS2500 pads on and be amazed :-) Link to post Share on other sites
jayvwvr6 0 Posted November 8, 2005 Author Report Share Posted November 8, 2005 nice one mate,thanks for that,jay Link to post Share on other sites
