Roop 0 Posted November 18, 2003 Report Share Posted November 18, 2003 1998 VR6 Highline.heated seats nos functioning.only one element seems to work on passanger seat - none on drivers seat.any one know how to go about repairing this.ThanksRoop. Link to post Share on other sites
Mangold 0 Posted November 19, 2003 Report Share Posted November 19, 2003 I believe its normally down to the heat element thats in the seat itself, check the connector under the seat thats faulty (may have come lose) or maybe (I'm not sure how the switch is wired) swap the rotary heat control over to prove its not that. I wouldnt imagine the seats are individually fused so if your still not having any luck it would be a case of swopping drivers and passengers seats over to prove its the heat element.... Would imaging its not that cheap to sort out as you would need some upholstery work done on the seat and purchase the heat element..... stick to a hot water bottle if I were you if it turns out to be the latter! Hope this is of some help? Link to post Share on other sites
