stockers 1 Posted September 27, 2005 Report Share Posted September 27, 2005 will i have any problems getting my 205 45 15 rubber over 8"x15" rims ?does the tyre pressure alter? Link to post Share on other sites
The1andonlygav 0 Posted September 27, 2005 Report Share Posted September 27, 2005 nope, i've got 215/45/16 on my 9 x 16. you'll get a nice euro-look stretch on them. Link to post Share on other sites
Big P 1 Posted September 27, 2005 Report Share Posted September 27, 2005 Shouldn't of thought so mate, i used to run 195/45/15 on my bbs split rims and they were 8 1/2 wide, on my old mk2 G60 8) Paul Link to post Share on other sites
stockers 1 Posted September 27, 2005 Author Report Share Posted September 27, 2005 cool, thanks guys Link to post Share on other sites
matth76 1 Posted September 27, 2005 Report Share Posted September 27, 2005 will i have any problems getting my 205 45 15 rubber over 8"x15" rims ?does the tyre pressure alter?Wouldn't have thought so as the standard 15" takes 205 or 195 on a 50 profile. You are going to a 45 tyre profile which will make the overall wheel size smaller. Normally you'd have to go up to a 16 or 17" to have a 45 profile and keep the overall size the same. The only very slight thing you may notice is your speedometer goes up the scale a fraction quicker when in fact you are going slower (only by a fraction mind you). That is because you have reduced the overall wheel diameter (hub plus tyre profile). Conversely if you fit huge wheels that are bigger than standard (again hub diameter plus profile) then your speedometer will say less than you are actually doing - eg. says 70 but you're doing 73 in fact. Normally its hardly noticable... (unless you go through a speed camera) Its apparently because the gearing and speedometer is linked to the wheel size. Although in your case I can't see any problems at all. Should look good though being a smaller profile. Link to post Share on other sites
