tasja 0 Posted July 19, 2005 Report Share Posted July 19, 2005 i have a water leak just above my oil cooler i looks like plastic,c ould anyone please tell what that part is called.many thanks Link to post Share on other sites
VR6Pete 1,455 Posted July 19, 2005 Report Share Posted July 19, 2005 from yout description, I'd say either;1) crack pipe2) thermostat housing (quite common)Pictures would clarify this. Link to post Share on other sites
jayvwvr6 0 Posted July 19, 2005 Report Share Posted July 19, 2005 if its the long plastic pipe that runs from the thermo housing to the back of the water pump(left had side looking at it) id say it wasnt the pipe but the rubber o seals that it sits into,these perish and leak. Link to post Share on other sites
tasja 0 Posted July 19, 2005 Author Report Share Posted July 19, 2005 hi therei do not think that it is the thermostat housing cause i have just replaced about a month ago.it may be the long black pipe from the housing to the water pump. if it is how do i remove it.thanx Link to post Share on other sites
jayvwvr6 0 Posted July 19, 2005 Report Share Posted July 19, 2005 remove the front only part to the thermo housing(3 allen key bolts facing the radiator) pull this cover hard once the bolts are out coz its a tight push fit,when this pops of the long black pipe will be attatched to this,then wiggle it a bit pulling at the pipe to remove it from the back of water pump,did you replace housing or a garage?as this part would of been disturbed when changing themo housing and should of had new seals replaced then?your need 3 new seal,there only cheap from vw,your best to get these before doing the above. Link to post Share on other sites
tasja 0 Posted July 20, 2005 Author Report Share Posted July 20, 2005 hi therei found the leak it was not the platic pipe from the thermostat to the water pump.it was a plastic part behind the plastic pipe. i put heat resistant silcone in the hole and the leak stopped.i am going to go to the dealer to find out what is the name of that plastic part.thanks for all the help tasja Link to post Share on other sites
